2510 mule
Old Dec 1, 2005 | 12:30 AM
SSMULE's Avatar
Default 2510 mule
Just got a 98 mule to cruise around at Barona Speedway in the pits. The oil seal on the shaft was leaking. I discovered the shaft had too much play in it. Took off the side cover of the crankcase only to discover that the bearing for the shaft was the aluminum crankcase cover! Steel spinning against never works for long, so the crank and the side cover both have to be replaced. I CAN REBUILD A SMALL BLOCK CHEVY CHEAPER!!! I was wondering if anyone has explored the idea of having the crank machined and crankcase machined to allow for the installation of a REAL bearing...
Old Oct 2, 2019 | 02:51 PM
Weaver Cain's Avatar
Default jumping out of 4 wheel drive
I have a 2000 2510 I was driving it one day and when it is in 4 wheel drive I hear a popping noise coming from the front . it is not constant probably every 10-15 seconds apart
mrbailey959
Sep 17, 2019 04:31 PM
Texas-Mark
Jun 15, 2016 06:03 PM
New Guy
Sep 10, 2007 12:56 AM
SSMULE
Sep 10, 2007 12:33 AM
dalbright
Jun 12, 2007 01:03 AM
