2017 Trans 4010 rear cylinder coil not firing
I have 2017 4010 Trans, the rear cylinder is not firing. I removed the plug to check spark using the front coil, spark excellent. I replaced the rear coil, still no spark on the plug. The engine will run on the front cylinder with very limited power. Any suggestions on where to go next?
Mike K
Aug 11, 2016 01:12 AM
