2007 3010 trans mule. Blowing main fuse. NEED HELP
I was driving the mule and it just quit. After checking for the problem I found that the 30 amp main fuse was blown. I replaced the fuse and as soon as I turned the key, it blew again. I have found that one side of the fuse terminal is grounded. I have traced the ground back through the switch and I have hit a road block. I can find anything that would be causing a ground on the acc side of the switch. I think I have moved every wire and unplugged everything I can find in the front and it's still grounded. Acts like its the brown wire that is grounded.
BruceEddy
May 27, 2024 10:47 PM
