2003 ZRX1200 No Start No Lights...Nothing
Old 09-17-2011, 11:32 PM
Kawzrx12's Avatar
Default 2003 ZRX1200 No Start No Lights...Nothing
Hello All, could use a little advice. I have a 2003 ZRX1200 that I have not ridden in about a month and a half. When I went to start it today it barely cranked for about 1 second then was dead. I removed the battery and put it on a slow charge for a couple of hours. I reinstalled the battery and I have no lights or crank with key turned on. Battery shows a voltage of about 13v. I tested the voltage across the starter relay and it is .5v with the key on and 12.8v with the key off. Anyone have any idea what is going on? I took the battery back out and will charge overnight but I should at least have lights with a 13v battery I would think. Also, I checked all of the fuses in the junction box as well as the starter relay and have continuity across all of them. Thanks in advance for any responses.
Old 09-18-2011, 12:16 AM
Kinda sounds like your ignition switch is not making good contact. Is the switch turning freely? or the ground is just not making good contact from your battery.
Old 09-18-2011, 12:27 AM
Kawzrx12's Avatar
Dragon...ignition switch (key) moves freely, the other end of the ground wire seems to be buried under the airbox and is not easily accesible. I may try to run and alternate ground to see if it lights up. Thanks for your help, I'm hoping I didn't smoke the starter relay but if I did, wouldn't I still have lights or does the current pass through the starter relay first before it passes through the headlight relay? I have no lights at all, no dash lights, nothing.
Old 09-20-2011, 09:39 PM
Kawzrx12's Avatar
Default Update 9/20/11
Update...Even though the battery was showing a voltage over 13 volts it failed a load test miserably. Under a load, the test needle immediately went to "BAD" and when the load was released the needle went back to 13 volts quickly, indicating a bad or defective cell. I bought a new battery, slow charged it, installed it and the bike lit up like a Christmas tree. I was surprised that the old battery showing 13 volts would not at least light up the dash lights, but it did not. Thanks Kawasaki Forums.
Old 09-22-2011, 03:44 AM
Thanks Kawzrx12 on this update and congrats on the fix
frankthetank
07-10-2009 03:11 PM
RUSH
ZRX1200
04-03-2009 06:45 PM
slip
05-15-2006 01:53 AM
Jutboy
02-24-2006 01:58 PM
slip
02-15-2006 04:41 AM
Quick Reply: 2003 ZRX1200 No Start No Lights...Nothing
