2000 zx6r won't start
will start when push started.not battery, replaced selonoid. fuses all work, horn/blinkers workcould it be starter switch/button? is there a way to check? motor does not crank over, there is no clicking or noise, completely quiet. thank you.
Use your meter to check. Most of the time though it is a battery issue and not the switch. But you can check continuity with your meter on the switch to verify operation.
Welcome to KF!
Welcome to KF!
