I have vertical play in my crank shaft so I’m replacing the crank and crank shaft along with the barrings but is in necessary to take all the gears and everything off the clutch side or can I leave those gears in place so I minimize error when I put it back together. Clutch is already off. Here is a picture so you see what I see
