1990 EX 500
Old Jan 2, 2007 | 09:18 AM
Default RE: 1990 EX 500
ORIGINAL: dogdragon
Hmm another EX 500 with magnets destroyed eh? it seemms to be a common problem with that model. I just deplaced one for an 86yr old kwak rider. he thought it was just the starter moter but I found loads of bits of magnet had jammed up the starter chain.
I managed to get a second hand stator and winidings, there is only one magnet by the way.
Si
www.dogdragons.com (my bike bike web site)
P.S. you'll need a 4" or 6" 3 legged puller to pull the gerator off the crank.
so why did the magnet destroy? any answers on that?
Old Jan 2, 2007 | 09:37 AM
dogdragon's Avatar
I can say that we found nothing that could have get cought in between the magnet and the windings.
The machine was about the same age as this one. The magnet is made in one piece as a ring in the flywheel casing. I guess that vibration and age had caused the magnet to break up. when this happens it catches into the windings, which also get damaged.
if I can remember I think it cost £180 for the parts, and that was used parts too.
Si
Old Jan 2, 2007 | 09:43 AM
thanks, understood.
I checked on one of the rides to replace, $1600
ouch.....for the kit version.
edit: for one of my rides of course.06 10r. kinda steep in price.
Old Jan 5, 2007 | 04:02 AM
dogdragon's Avatar
Sounds like I saved him a small fortune then, good.
Si
Old Jan 5, 2007 | 07:13 AM
true different ride, but I am still curious on the cause on the EX.
Old Jan 5, 2007 | 07:19 AM
dogdragon's Avatar
Like I said, we think it's due to vibration. figure it, that magnet spins with the crank, so it does the same RPMs, those two little pistons cause vibration. The magnets can only take so many vibrations before they just start to break up.
I don't know what material they are made of, but they just cant take it.
I've noticed most generators on most bikes it's the magnets that are static while the windings rotate. This is not true on the EX
Si
Old Jan 5, 2007 | 07:24 AM
so must be the same magnets in the 04 and 05 10r's then.
Old Jan 5, 2007 | 07:28 AM
dogdragon's Avatar
I'm checking my zx10a manual now, with u soon, noticed the VFR honda has magnets that rotate while windins stay still, co maybe it's just a bach of magnets from that year that give up
Old Jan 5, 2007 | 07:32 AM
dogdragon's Avatar
not the same, generator on the RX, ZX10's zx9's &zx1100have external generators. not the same at all (soz about the spelling, but it's 5:30 am here and I'm getting tired), If I remember correctly it's the GPZ 500 & maybe the 550 which has the same generator as the EX.
Old Jan 5, 2007 | 07:43 AM
get rested dog, no prob
