1976 KE125 Stalling Out
Old Jul 6, 2013 | 05:45 AM
Mtb2Moto's Avatar
Default 1976 KE125 Stalling Out
Hey all, I have a 1976 KE125 i'm trying to get running again with my friend and I just have no idea why it is stalling at low rpm. It won't quite kick start, but will bump start almost every time. however, if you don't give it gas as soon as it gets going it dies. I thought it was a problem with not getting enough fuel, but it seems like it might be getting air in somewhere. It runs great at 3,000 RPM's and up, but struggles or dies at anything lower and will stall as soon as i pull in the clutch to shift. Shifts fine and rides fine, no back firing or sputtering, but if you let it get below 2,000 it'll shut off. Carb has been cleaned, air filter cleaned, new fuel, fuel lines checked. I'm not good at describing problems so if any more info is needed please ask, any knowledge please share!
Old Jul 6, 2013 | 10:08 PM
Almost sounds like your pilot jet or orifice's are not clean. Pilot power is good up to maybe 1/8th throttle response. If you run the choke up to that point, what does the ride do?
Old Jul 7, 2013 | 06:27 PM
Mtb2Moto's Avatar
Well, the wise guy who owned it before me thought it would be a good idea to cut the choke cable, so it can't be choked at all. and alright, I'm going to pull the carb apart and clean it again.
Greenshirt
Aug 13, 2012 12:01 AM
driver415
Apr 13, 2010 10:56 AM
capt-yo
Apr 5, 2010 09:21 PM
a1parrothead
Jul 15, 2009 03:08 AM
59allann
Jan 15, 2007 03:17 PM
