1200 USD/RIM/TIRE QUESTION
Old May 4, 2007 | 04:21 PM
alwayskaos's Avatar
Default 1200 USD/RIM/TIRE QUESTION
Question:
I have a wrecked 04 ZRX 1200 that needs forks, rims, and tires. I will be purchasing a USD front end in the next few days. If I put a ZX12 USD assembly up front, would the same ZX12 rear rim fit? If not, which model Kawasaki can I use for the forks/front/rear rims? I read some prior posts regarding USD's and it seems like some are slightly shorter than others. Of course I can machine a stepped upper tree, but is there a year/model Kawasaki that fits in regards to the length. Since I will probably be using the wheel that comes with the USD front end, rotor size and calipermounts are not an issue.
Thanks
Old May 4, 2007 | 06:39 PM
Default RE: 1200 USD/RIM/TIRE QUESTION
I am 100% sure but I thought they both had 17" rims and used the same brand of forks. Not sure on the length question if the the forks and the rim are the same. Unless the springs were changed for sag and the oil level or weight was changed.
Old May 4, 2007 | 06:40 PM
edit: Not 100% sure.
The forums are kicking my **** this morning.
darkmarc
Aug 24, 2013 09:37 PM
dan888
Sep 9, 2011 08:53 PM
gustavo2011
Aug 17, 2011 03:15 PM
rustsmit
May 14, 2009 03:56 PM
vuskavich
Ninja ZX-10R
Apr 5, 2007 08:03 AM
