05 zx6r coolant?
Old Sep 9, 2011 | 08:38 PM
Scorpiozx6r's Avatar
Default 05 zx6r coolant?
i got my bike not too long ago quick question, i accidentaly put too much coolant in resevoir and it is over the full line. what should i do?? will this harm my bike in any way answers are greatly appreciated.
Old Sep 9, 2011 | 09:01 PM
jeffzx9's Avatar
Welcome to the forums, Scorpio. Not a problem on the coolant.
Can do a couple things. Go buy yourself a stainless turkey baster (yes; one of those bulb things you use at Thanksgiving) at Target. Connect a 6" rubber hose to the end. Pop your rad cap and suck away......with the baster!! A turkey baster has 1001 uses around the shop. Clean and dry when you're done. Do NOT re-use for the turkey.
Should be a small bleeder screw near the water pump area on your engine, which lets you bleed off the air when you change your coolant. Put a drip pan underneath, turn the screw, bleed off coolant, and re-tighten (not TOO tight.)
Welcome again. Gear up; stay safe.
Old Sep 16, 2011 | 02:37 AM
hmmm, what is that taste???? (on turkey day. ) lol
Depending on how much you overfilled will kind of dictate on what you do. Going over a little above is not disastrous. But yes, keep it simple.
407guy
Oct 10, 2023 01:42 AM
Derosian
Ninja 250R
Feb 6, 2008 09:20 PM
importmonkey
Jan 3, 2008 01:38 AM
trav_02t
Jun 9, 2005 05:27 AM
