stripped oil-plug
Old May 18, 2011 | 10:16 PM
bdparmet's Avatar
Default stripped oil-plug
I seem to have stripped my oil plug (83 KZ550) - just hoping somebody could tell me whether the Kawasaki engineers used a plug metal that was softer than the oil-pan metal - I'm worried. Suggestions?
Old May 20, 2011 | 12:47 AM
I have not seen that one yet. Good for you that the plug is the one that went and not the pan threads. Are you sure that you did not cross thread the bolt on the oil change? (bad thoughts....) How was the washer condition for the pan/bolt? Welcome to KF
Old May 20, 2011 | 01:01 PM
gammac's Avatar
Check oil pan threads with a bolt/plug of the correct thread diameter/pitch. If it won't go in (using finger pressure) you may have residue in the oil pan threads which you may be able to clear using a tap of the correct diameter/ pitch. If their is a problem in both respects you may be able to get the pan "helicoiled".
gammac
Old May 20, 2011 | 01:43 PM
bdparmet's Avatar
I replaced it with the same 12/1.5 plug from NAPA and all seems okay- got lucky. What a lummox...
Old May 28, 2011 | 01:06 AM
jeffzx9's Avatar
Good advice from gammac^. You DID get lucky. Always finger-tighten the first few threads on filters, plugs, drain plugs, etc. I've done that same OMG on aluminum Land Rover heads on the plugs next to the firewall (which are inaccessible to humans) and have the taps and thread restorers to prove it.
WHEW! Glad to hear things worked out.
Welcome to the forums, bd.
Gear up; stay safe.
smithjNW
Feb 2, 2015 02:07 AM
dynamic098
KLX300R
Jan 12, 2008 01:29 AM
dynamic098
Dec 26, 2007 02:11 AM
swoop4321
May 1, 2007 05:25 AM
gotrice
Jan 10, 2006 10:15 PM
