Oil drain plug.
Old Mar 6, 2006 | 12:20 AM
Notstock's Avatar
Default Oil drain plug.
Does anyone know where to get this type of plug for a 95 zx7. I see them for 96 and up but not 95.
**Updated picture**
[IMG]local://upfiles/346/8E84909C1DBA49B69E13B6EF4EBD7775.jpg[/IMG]
Old Mar 6, 2006 | 04:26 AM
txredneckmedic's Avatar
Default RE: Oil drain plug.
whats so special about it?
Old Mar 6, 2006 | 05:12 AM
Notstock's Avatar
It is drilled so it can be safety wired. This particular one has a magnet in the tip that will attract metal partials in the oil system.
Old Mar 6, 2006 | 07:12 AM
BigRig18Wheeler's Avatar
Does 96 drain plug have the same thread pitch as the 95 drain plug?? I think they are both 12x1.50mm. Don't qoute me on that though... you might double check.
Old Mar 6, 2006 | 07:18 AM
Yup, sure enough. Went to bikebandit.com and checked out the oil drain plug for 95 and 96, and they are both the same part #. It is a 12x1.50mm plug. The 96 should work with no problem...
Old Mar 7, 2006 | 05:28 AM
But is that plug a stock part or aftermarket with the magnet and predrilled? What link did you find that Notstock? Nice find BigRig.
Old Mar 7, 2006 | 05:55 AM
Notstock's Avatar
It was from an ebay actuion that has ended and the seller doesn't seem to sell them anymore.
Thanks bigrig for the info bro.
I really want to find one of these in aluminum, I f*cked mine up by over tightening with a cresent wrench [:@]
Old Mar 7, 2006 | 06:15 AM
http://www.bizrate.com/buy/noncat_pr...266163486.html
No problem at all. Here is a link to some safety wire drain plugs. Not sure if they have the magnet tho' ....
Old Mar 7, 2006 | 06:18 AM
I have not recorded any oil pan oil temps, but at the moment do not like the idea of al with a press fitted magnet at the moment. Al expands pretty good depending on the hardness and thermal caps. I would think a steel plug with a magnet would be more durable in the long run. But, I will have to make an Al plug with a pressed in magnet to try it out. You are getting my brain to working again Notstock. I will use my 7 and 10 as the guinee pigs! lol Oh, no cresent wrenches!
Old Mar 7, 2006 | 06:29 AM
You can always buy a magnetic plug and drill so you can safety wire it yourself.
http://bernardembden.com/xjs/plugwire/index.htm
That's what this guy did...??? Could not find a drain plug safety wired and magnetic. Worth a try tho
