Kawasaki KX250F coolant problem
Old Sep 28, 2023 | 03:11 PM
millwright's Avatar
Default Kawasaki KX250F coolant problem
Ok need help! Grandson has a 2009 KX250F dirtbike. It keeps dumping the coolent out the overflow. Have been told it was the radiator cap Replaced it with a new gage cap . Still builds up pressure and dumps the coolent. Then told the radiators must not be sealing where the cap sseal sits. Replaced the radiators with larger raceing ones. Did not fix the problem. Anyone out there have any Ideas? Or have had this happen to them. Thanks
Old Oct 2, 2023 | 08:40 AM
onebus's Avatar
Default Coolant loss
It’s very possible that you have a blown head gasget. If the gasget is blown between the water jacket and the cylinder, compression will enter the cooling system and push the coolant out. Remove the spark plug and get an adapter to put compressed air into the cylinder an see if it blows out the coolant. If it does, it’s the gasget
Old Oct 6, 2023 | 12:56 PM
millwright's Avatar
Default coolent probblem
thanks will chack that.
zacoyote
KX250 & KX250F
Aug 25, 2020 12:19 AM
Goon
KX250 & KX250F
Mar 26, 2020 11:42 PM
Tre Breeden
KX250 & KX250F
Feb 18, 2018 03:59 PM
Ronnie829
Nov 28, 2016 05:34 AM
lashlarew
KX250 & KX250F
Feb 21, 2013 02:11 AM
