2009 ninja 650 not starting
Old Jul 13, 2019 | 06:36 PM
Chris!'s Avatar
Default 2009 ninja 650 not starting
09 ninja 650 that is not starting unless I pour gas in the throttle bodies or if I use starter fluid little bit of history about the bike it sat outside for at least three months in the florida elements with out a cover on it so far I have replaced the starter solonoid fuel pump spark plugs and tip over sensor still no luck cranks over fine but just doesn't catch I have spark fuel pump sounds like its coming on I checked all the fuses new relay box and ecu cleaned all fuel rails and injectors replaced all old gas I have no idea where to go from there oh and it has no codes when I tried to use the self diagnose mode all ground wires have been cleaned please help here is a link of a youtube video with gas tank plugged in and fuel lines hooked up
Old Jul 30, 2019 | 10:25 AM
DanZ's Avatar
Chris, have you gotten any further with this? I see the thread is getting old and just wondering how it's going?
Old Dec 14, 2023 | 09:25 PM
Wesley's Avatar
Default I have exact same issue any fix nod light goes dim while cranking over and opening th
plugs out, crank over 150 psi compression, noid light goes dim while cranking, battery good ,checked, bad relay box ? What's wrong stumped
bigmuse85
Ninja 650R
17
Nov 5, 2013 11:15 PM
bigmuse85
Apr 29, 2013 01:04 AM
tfulker99
Oct 15, 2011 02:34 AM
iroc
Ninja 500R
19
Sep 3, 2007 04:47 AM
fredhill032188
Jul 24, 2007 10:47 PM
