2009 ninja 650 not starting
09 ninja 650 that is not starting unless I pour gas in the throttle bodies or if I use starter fluid little bit of history about the bike it sat outside for at least three months in the florida elements with out a cover on it so far I have replaced the starter solonoid fuel pump spark plugs and tip over sensor still no luck cranks over fine but just doesn't catch I have spark fuel pump sounds like its coming on I checked all the fuses new relay box and ecu cleaned all fuel rails and injectors replaced all old gas I have no idea where to go from there oh and it has no codes when I tried to use the self diagnose mode all ground wires have been cleaned please help here is a link of a youtube video with gas tank plugged in and fuel lines hooked up
Chris, have you gotten any further with this? I see the thread is getting old and just wondering how it's going?
I have exact same issue any fix nod light goes dim while cranking over and opening th
Originally Posted by DanZ
(Post 547006)
