High Idle 3K
Old Mar 15, 2009 | 07:01 PM
Kawkeith's Avatar
Default High Idle 3K
Hi all,
Just brought my bike out of its' hibernation and it started right up (Yay) but it idles at 3K. I used stabil before I put her away could this be the reason for the higher RPMs? This is my first time bringing a bike out of slumber and I thought I would check. It is a 86' 750 Vulcan btw.
Keith
Old Mar 15, 2009 | 08:59 PM
May be cold. What happens if you unstick your choke? I am sure that the cable was lubed. right?
Vote on the botm: https://www.kawasakiforums.com/forum...ad.php?t=27221
Old Mar 15, 2009 | 09:50 PM
Kawkeith's Avatar
After further inspection I believe that my choke cable may be stuck. It normally is at 3K full choke and 1100 without. I went out to start it cold and it started right up without the choke...that doesn't normally work. when I apply the choke when the bike is running there is no change in RPMs. Can anyone tell me how to check and or fix the problem?
Keith
Old Mar 16, 2009 | 12:33 AM
how does the choke lever react? Does it move back and forward easily? Check on the net or your factory manual on how to lube it. Then check the numbers of freeplay your manual states. In other words, check your manual. A good resource to own. Good luck.
Old Mar 22, 2009 | 02:42 AM
Kawkeith's Avatar
Turns out it was the choke cable. Easy fix from my local Kaw dealer. Doesn't hurt that the owner is one of my student's parents. But overall got a good report and am ready to ride. Had the front barkes replaced while I had it in the shop. Thanks for your responses.
Old Mar 22, 2009 | 05:02 AM
Right on, congrats on the fix.
jellyfish
May 25, 2007 05:37 AM
Stumpy
Apr 28, 2007 03:40 AM
MikeA12
Feb 14, 2007 03:07 AM
MikeA12
Jan 24, 2007 05:11 PM
Sublime
Aug 20, 2006 04:08 AM
