Hi To all, Trying to sort my zzr600
Old Mar 18, 2007 | 11:39 AM
GERARDPA1972's Avatar
Default Hi To all, Trying to sort my zzr600
Hi, Ive got a 1993 - e1 zzr600, i paid £600 for it in july 2006. Well im trying to get it sorted out once and for all. Ive replaced the plastics, the tank, and im in the process of spraying them black. I got hold of another frame and sprayed it satin black, looks so cool. Also finally got hold of a Hagon rear shock and front springs!!! yipee. My question is if i replace air filter with a K&N, change the carb needles and get a pair of viper race cans, Will it improve my top speed, i can get about 151 at the moment. I want to try and get it to about 165, also ive heard of spitfire ht lead connectors which is supposed to give you an extra 5bhp. soooo just like to know!
Thanks
Old Mar 24, 2007 | 02:04 PM
ninjabarmy's Avatar
Default RE: Hi To all, Trying to sort my zzr600
Before you spend any more on the go faster bits, maybe you should consider the brakes? Always remember, there's only a couple of square inches of rubber between your a**e and the tarmac. Gravel rash is painful. Slow down and enjoy the view.
Mike
Old Mar 25, 2007 | 02:04 AM
Yup, gear first, suspension and tires second.
Old Mar 26, 2007 | 11:32 PM
SERGE's Avatar
Once gear and breaks are done, a change of ratio by means of a smaller rear sprocket (or a larger front one) may do the trick. It depends if teh bike has the "grunt" to pull a taller ratio.
Old Mar 27, 2007 | 08:58 AM
with the tires and suspension to carry it thru.
rocketman
Dec 16, 2007 05:23 PM
Sturgell
Jun 22, 2007 03:10 PM
Kawi Wawi
Apr 8, 2007 02:30 AM
BLKPEARL
Dec 26, 2006 05:54 PM
chrisrigas
Apr 27, 2006 03:55 AM
