The aftermath
Old Jul 4, 2007 | 01:22 AM
walight01's Avatar
Default RE: The aftermath
just remember to put a good coat of oil on the ring of the filter and remember to only put it on hand tight. the high heat of the motor will sorta bond the filter to the motor and if you put it on real tight and or there isn't a good oil ring on the filter, it will be that hard to get off. Good luck in the future and as n/s said it will be easier and easier.
Old Jul 5, 2007 | 02:43 AM
Mizz ZZR's Avatar
Goodness me!
I'm a girl and it only takes me 30 mins fairings included. After the oil is out, always make a point of putting the plug back in before completing any other part of the job.
Works for me
Old Oct 12, 2007 | 10:50 PM
yoman1's Avatar
lol, I've been there
Old Nov 2, 2007 | 12:41 PM
Talca's Avatar
i got a new ford truck that i even resorted to yelling at it just to get the filter that came fromt he factory off.
Old Nov 2, 2007 | 06:34 PM
ninjan00b's Avatar
im pretty sure mechanics overtighten all the nuts and bolts so that you can't get them off and therefore resort to taking it back to them, but i could be wrong.
Old Nov 2, 2007 | 09:33 PM
KNEEDEEPKZ650's Avatar
GOT A GOOD LAUGH AT THAT ONE .AND STILL LAUGHING!BEEN THERE DONE THAT.
Old Nov 3, 2007 | 11:56 AM
Truckman's Avatar
we had 2 boneheads at work yesterday tighten the 2 fuel filters on a new Mack truck so tight that it distorted the filter housing and wouldn't let the engine run over 1700 rpm because the fuel system would suck air into the EUP pump.....I broke my filter wrench removing them.I had to use a chain wrench and a cheater pipe to get them off.
Once the filter contacts i go 3/4 of a turn by hand ...that's it.oil the o-ring too.
Old Nov 3, 2007 | 05:21 PM
xchang's Avatar
Wow, as I was reading, I was thinking if someone overtightened it AND crosstreaded it somehow... LOL! Glad everything turned out and you'll be sure to double and triple check things from now on because of that one mistake.
Old Nov 4, 2007 | 03:30 AM
Talca's Avatar
ORIGINAL: ninjan00b
+1
Old Nov 4, 2007 | 03:41 PM
OMalley912's Avatar
It's all a learning curve. No worries...we laugh with you
Mott Power
Apr 29, 2008 02:30 PM
Ninjamaster
May 29, 2007 07:26 AM
