2003 zr7s
Old 07-08-2018, 02:15 AM
Troymajor45's Avatar
Default 2003 zr7s
Hi I have a 2003 zr7s I just bought it and it was laid down and I have replaced the pulsing coil the rotor and bolt and cleaned carbs put new fuel in it because it sat for 2 years it runs but it has bad throttle response if I peg the throttle it spits and spuders and eventually it revs hi what could be the problem please I’m trying not to have to take it to a mechanic.
Old 07-09-2018, 03:29 AM
Rob9876's Avatar
About the only active discussions on this forum revolve around KLX 250S bikes. For future questions, you may have better luck at this forum:
Old 07-09-2018, 11:27 AM
Worked in a dealership and saw this numerous times. Odds are the old gas evaporated leaving crud in the float bowls. When fresh gas comes in the crud either floats bits out into the very small pilot jets, or gets gummy and plus them. Characteristic is runs on choke, may idle, but will not take normal smooth throttle. If you keep working the throttle to get the revs up you eventually get to the level where the slide/needle/main jet control throttle. They don't clog easily since they are bigger.openings.
You can have the carbs cleaned. If you can take them off the bike and pull the pilots to see if they are clogged. You may need to tear them down and have them cleaned in a carb washer or ultrasonic cleaner. They can get cleaner in and worked around in areas that are unreachable with spray and a wire. If you do them yourself, look up something about using Pinesol to clean carbs. Here is a link to a thread on it at the ADVrider forum
One possibility before going to the tear down, some riders have done something called Seafoam gas treatment, which may resolve the problem without tear down. Never tried it and don't know for sure.
lhemrick
03-07-2019 03:58 PM
pasuxx
Classic Touring Bikes
01-01-2018 04:03 PM
Southpaw
04-27-2012 04:06 AM
rrich224
03-02-2011 11:42 AM
amybeth4
Ninja 250R
06-26-2007 02:05 AM
Quick Reply: 2003 zr7s
