2003 zr7s
Hi I have a 2003 zr7s I just bought it and it was laid down and I have replaced the pulsing coil the rotor and bolt and cleaned carbs put new fuel in it because it sat for 2 years it runs but it has bad throttle response if I peg the throttle it spits and spuders and eventually it revs hi what could be the problem please I’m trying not to have to take it to a mechanic.
About the only active discussions on this forum revolve around KLX 250S bikes. For future questions, you may have better luck at this forum:
You can have the carbs cleaned. If you can take them off the bike and pull the pilots to see if they are clogged. You may need to tear them down and have them cleaned in a carb washer or ultrasonic cleaner. They can get cleaner in and worked around in areas that are unreachable with spray and a wire. If you do them yourself, look up something about using Pinesol to clean carbs. Here is a link to a thread on it at the ADVrider forum
One possibility before going to the tear down, some riders have done something called Seafoam gas treatment, which may resolve the problem without tear down. Never tried it and don't know for sure.
Southpaw
Apr 27, 2012 04:06 AM
