DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Radar Detector Mount Location
Old May 26, 2006 | 02:39 AM
speedracer138's Avatar
Default Radar Detector Mount Location
Here's a pic of where I have my Radar Detector mounted. I just used the suction cups that it came with and the botton rests on top of my guages. Very secure!
[IMG]local://upfiles/1485/1267424DDBC44D489A70343F2511FE33.jpg[/IMG]
Old Oct 23, 2006 | 09:01 AM
bsballs09's Avatar
Default RE: Radar Detector Mount Location
you just get some extra wire and tie it into the battery or a fuse?
Old Oct 24, 2006 | 06:33 AM
GS247's Avatar
does it work just as good through the tinted wind screen?
Can you hear it or do you just look for the light?
i've been thinking about putting one on my bike.
Old Oct 25, 2006 | 04:16 AM
firstninjabike's Avatar
Hey bsballs use a battery opperated one so you dont have to put it to a fuse or a battery
Old Oct 25, 2006 | 04:54 PM
Notstock's Avatar
ORIGINAL: GS247
It will work fine behind the dark wind screen.
Old Oct 31, 2006 | 07:14 AM
ORIGINAL: bsballs09
No, the wires were long enough. I just bought a power outlet adapter and wired in in to my fusebox. There's a power terminal that's energized only when you turn on the key. I plugged a spade terminal to it for the positive and grounded it to the battery for the negative.
Old Nov 7, 2006 | 07:20 PM
drummerboy01's Avatar
Notstock------- how does that stabilizer work for you?
Old Feb 28, 2007 | 09:47 AM
Soldier4rmTexas's Avatar
How Do You Power The Detectoor Bro?
Old Mar 1, 2007 | 09:44 AM
You can power it directly from the battery or hook it up to an accessory power source so it come on only when the ignition is on. The fuse box had an empty 12Vpositive spot with a spade terminal that you can plug into. The negative can ge grounded to the battery or a good ground on the frame. Get a12 volt cigarrette lighter adapterpower outlet from Wal-Mart or Radio Shack or ?. This way it's multi purpose.
Old Mar 1, 2007 | 09:54 AM
Odimus's Avatar
that looks like a perfect spot for the gps...
ol'klx-er
Jan 29, 2014 06:28 PM
Ace28
Aug 7, 2009 06:15 PM
xyz1000rr
May 18, 2007 12:57 AM
BattRECON
Sep 16, 2006 11:21 PM
Gerg
May 28, 2006 10:48 AM
