DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
HOW TO GET GP (REVERSE SHIFTING)
Old May 10, 2008 | 04:15 PM
mikezx6r's Avatar
Default HOW TO GET GP (REVERSE SHIFTING)
OK IVE POSTED ON ALOT OF OTHER THREADS THIS HOW TO AS WELL BUT HERE IT IS MANY PPL WERE WONDERING HOW TO GET GP OR REVERSE SHIFTING ON UR BIKE THIS IS 1 UP AND 5 DOWN. THIS WORKED ON MY 01 ZX6R
IT IS VERY EASY AND ILL TAK YOU THROUGH THIS STEP BY STEP.
1ST IS TAKE OFF THE BOLT ON THE CLAMP CONECTING TO YOUR GEAR SHAFT.
2ND IS TAKE OFF YOUR GEAR COVER SHOULD BE 5 BOLTS IF IM NOT MISTAKIN.
3RD TAKE OFF THE CLAMP CONNECTING TO YOUR GEAR SHAFT AND ADJUST IT TO ABOUT 11 OCLOCK.
4TH PUT THE GEAR COVER BACK ON WITHOUT TAKING OFF THE CLAMP KICK YOUR SHIFTER DOWN TO MAKE SURE IT WILL KICK INTO FIRST WITHOUT HITTING YOUR GEAR COVER.
5TH TAKE THE COVER BACK OFF AND PUT THE BOLT BACK ON THE CLAMP AND TIGHTEN IT.
6TH PUT THE GEAR COVER BACK ON AND BOLT IT BACK ON
7TH IS LOOSEN THE TWO NUTS ON THE SHIFTER BAR AND ADJUST TO MOVE UR PEG WERE YOU FEEL IS COMFORTABLE.THEN TIGHTEN THE TWO NUTS
THIS TAKES ABOUT 20 MINS WITH ADJUSTING TO FIT WHATS COMFORTABLE TO YOU. IF YOU HAVE ANY QUESTIONS OR IF YOU WOULD LIKE I CAN TAKE PICS OF A STEP BY STEP ITS VERY SIMPLE AND WILL WORK ON MOST BIKES.
Old May 10, 2008 | 08:01 PM
evil636's Avatar
Knee Dragging Pimp
Default RE: HOW TO GET GP (REVERSE SHIFTING)
add pics with steps. thanks mike
Old May 11, 2008 | 01:49 AM
mikezx6r's Avatar
no problem pics will be up tomorrow
Old Jun 24, 2008 | 02:34 AM
zzrick's Avatar
Did it today and it seems to be good so far.
Old Jun 24, 2008 | 06:58 AM
kronus's Avatar
So what are the gains by doing this? Just curious.
Old Jun 24, 2008 | 08:31 AM
BP88's Avatar
ORIGINAL: kronus
I think it's faster upshifting when you can kick the shifter down rather than pull it up.
Old Jun 24, 2008 | 10:39 PM
mikezx6r's Avatar
ORIGINAL: BP88
ORIGINAL: kronus
agreed thats why i did it
Old Jun 25, 2008 | 02:36 AM
kronus's Avatar
Fair enough. Good to know.
Old Jun 25, 2008 | 02:47 AM
mikezx6r's Avatar
ive had 3 guys all experinced riders take mine for a quick ride and now i have 3 bikes to do this to
Old Jun 25, 2008 | 03:53 AM
zzrick's Avatar
I changed mine back to stocktoday.I like reverse shifting better, but the bike didn't like it[&o]I think the motion was all wrong because the linkage is toolevel and there is not enough leverage toshift correctly. If you guys are doing this be very carefulnot to be too rough with the kinkage, it is very soft aluminum. Oh well, guess I'll have to wait until I get some better rearsets to switch it around again.
