Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
awesome write up man. to be honest that is a little to advanced for me as a new bike owner. i would love to have that kit thou. wanna come to fl and install it?
You can send me your headlight and I can do it for you. It'll be a lot extra if I have to come and install it there. I'm sure one of the forum members near youcan help you install the kit.
will it be good for later if i want to put on hid lights... and are hid light any good... i herd from some one that it is the worst thing to put on your bike...
HIcktown I will help you install them. I am getting ready to do mine. So order your kit and then drop me a line.
ORIGINAL: Defective
ok I did this install myself!! it works fine when i turn it on but when i hit the high beams the 10 amp fuse blows.but if there's a 15amp fuse it doesnt blow.is this ok or what should I do?thanks
You have a bad connection or a bad ground. Make sure that you remove the paint on the frame where the ground lead terminal connects to at the Ram Air duct mount bolt.
Did you get the kit from me or did you follow the DIY instructions? Also, what is the wattage of the bulbs you're using? If it's higher than 60/55 watt, that is why you are blowing the 10 amp fuse. It's okay to use 15 amp but I recommend 10 amp. If the bulbs are 60/55 watt, then you may have too much resistance somewhere. Check your crimps. What gauge wires are you using?
i followed the DIY instructions .my bulbs are 60/55watt and I used 18 gauge wire.also now my running signal lights like you have in your headlight,both flash for each signal.what could it be?
