DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
Old May 7, 2007 | 06:05 AM
  #41
speedracer138's Avatar
Default RE: Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
You have a bad crimp, contactor connection somewhere for it to blow the 10 amp fuse. Are both Low & Hi beams coming on when you turn on the Hi beams? The low beams should go out when the Hi beams are on. Double check your wiring. On the Euro lights, The power wire to both bulbs should go to the Brown/ Silver Dot wire, The other wire should go to the LE T/S green wire & the RH T/S gray wire.
Old May 7, 2007 | 07:07 AM
  #42
likitysplit's Avatar
ok I checked it and both hi/low are on when i push high beams,what do I do
Old May 7, 2007 | 07:16 AM
  #43
also the ground is spliced in with the stock ground but still grounded to the air duct.should i disconnect the stock ground?
Old May 7, 2007 | 07:39 AM
  #44
No, the ground is fine. The wires to the relay is hooked up wrong. Check the diagram and redo those wires at the realy connector.
Old May 7, 2007 | 07:41 AM
  #45
ORIGINAL: speedracer138
Sorry, Here it is again.
[IMG]local://upfiles/1485/87977B575E8A48ECA22B69120D584E15.jpg[/IMG]
Use this hook-up diagram.
Old May 7, 2007 | 07:25 PM
  #46
I cant find the relay!!
Old May 7, 2007 | 07:26 PM
  #47
its not were that pic shows!!
Old May 7, 2007 | 08:48 PM
  #48
mikedrinfla's Avatar
The relay is an aftermaket relay that you where suppose to install. If you did not install the relay that is why you are having the problems that you are. Install a relay and that should take care of all your problems.
Old May 7, 2007 | 11:53 PM
  #49
oh I see now so were could I find this relay!!whats the part # or whatever I need?
Old May 8, 2007 | 12:47 AM
  #50
You should be able to get it from any auto parts store. Or any place that does car audio.
