DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
Old Dec 23, 2006 | 08:32 PM
BIG V's Avatar
Default RE: Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
looks great i love it but that is too much work for me for lights
Old Dec 27, 2006 | 03:12 AM
speedracer138's Avatar
Locate a constant (with ignition on only) power wire (brown wire with silver dots)and connect on lead of the (Turn Signal)TSto it and the other lead to the grren or grey wire of the harness'TS plug. This circuit find's the ground through the TS relay circuit and is interrupted when you actuate the TS's.
Old Dec 29, 2006 | 08:50 AM
biglg7's Avatar
How much for the kit
Old Jan 14, 2007 | 07:48 AM
CarpeDiem's Avatar
So - I tried this mod, and it didn't work. I double checked the wiring, and here is what happens: when the bike is running the constant (30) has power. With the low beams on 86, 87, and 87a do not. When I flip to the high beams 86, 87, and 87a get power. Of course 85 is always off. I tried this even without the wiring harness plugged in - so just the wires coming straight from the factory harness ... any ideas?
Old Jan 15, 2007 | 08:00 AM
ORIGINAL: biglg7
http://cgi.ebay.com/ebaymotors/ws/eB...DME:B:AAQ:US:1
Old Jan 15, 2007 | 08:12 AM
ORIGINAL: CarpeDiem
30should be the Lt Blu from the stock harness. 86 is the stockPink. 85 is the stock ground. 87a is theLO beam from the H/L and 87 is the HI beam from the H/L. Make SURE the ground is connected/ groundedto the frame. Scrape off the paint to make SURE it has good contact.
If it still doesn't work, check the power from your stock plugs and also make sure you wired everything properly. If it still doesn't work, get another relay.
Old Feb 1, 2007 | 12:02 AM
Latinimagexx's Avatar
hey speedhow much you charging for the wiring?
Old Feb 1, 2007 | 08:00 AM
  #28
$75 for the DIY kit and $150 for the Plug N' Play kit ($85 plus $65 refundable core charge).
Old Feb 13, 2007 | 06:11 AM
  #29
GGryphin's Avatar
How much for a complete plug in play for a zx6r 06? for a local texan? shipped to 77346
Old Feb 13, 2007 | 08:01 AM
  #30
Here's some info on the kits. I have them on ebay. Just let me know you're from the forum when you're paying.
http://cgi.ebay.com/ebaymotors/ws/eB...575&rd=1,1
