Dual Headlight Mod for 03-05 ZX6R/RR & 04-05 ZX10's by speedracer138
Locate a constant (with ignition on only) power wire (brown wire with silver dots)and connect on lead of the (Turn Signal)TSto it and the other lead to the grren or grey wire of the harness'TS plug. This circuit find's the ground through the TS relay circuit and is interrupted when you actuate the TS's.
So - I tried this mod, and it didn't work. I double checked the wiring, and here is what happens: when the bike is running the constant (30) has power. With the low beams on 86, 87, and 87a do not. When I flip to the high beams 86, 87, and 87a get power. Of course 85 is always off. I tried this even without the wiring harness plugged in - so just the wires coming straight from the factory harness ... any ideas?
ORIGINAL: biglg7
How much for the kit
ORIGINAL: CarpeDiem
If it still doesn't work, check the power from your stock plugs and also make sure you wired everything properly. If it still doesn't work, get another relay.
$75 for the DIY kit and $150 for the Plug N' Play kit ($85 plus $65 refundable core charge).
Here's some info on the kits. I have them on ebay. Just let me know you're from the forum when you're paying.
http://cgi.ebay.com/ebaymotors/ws/eB...575&rd=1,1
shipped to 77346
