Detailing Discuss detailing your ride within.
Sponsored by:
Sponsored by:
Painting Bike
Old Jan 17, 2012 | 10:38 PM
Southpaw's Avatar
Default Painting Bike
I am currently looking to paint my 1985 Ninja 600R and im not looking to spend alot of $$$ on doing so. I decided to test out the painting that I wanna do so I remover one of my side panels to test on. So here is what I did, I flipped the panel over to paint the back of it so if I messed it up (expected to) it would be hidden, I then sanded a 8" x 8" location and cleaned it throughly. I then applied a coat of rustulem spray can automotive grey primer, waited 15m and coated another layer and let dry for another 15m mean while I used a space heater (approx 3 feet away) to dry the paint. I then applied a coat of rustoleum bronze color spray can paint and waited 15m and repeated 2 more times. Then I applied a coat of rustoleum clear coat high gloss spray paint and let dry for 15m and then repeated again. It looks really good and feels great and I let it rest for about 18hrs and I pushed my finger nail on it and I can dig the paint off. Is there something I can do so this doesn't happen like letting it cure for a certain time or letting it rest more in between coats besides having it professionally done? Thank you.
Old Jan 31, 2012 | 05:28 PM
jeffzx9's Avatar
Southpaw, some paints will soften plastic because of the distillates used. I would recommend using paint which says the intended application is plastic. I like to do a quick alcohol wipe of the surface I'm about to paint, just to ensure no oils or water remain.
Any updates on your project?
Old Jan 31, 2012 | 11:43 PM
BleednGreen68's Avatar
Plus you will need a flex additive. I think duplicolor makes a paint just for plastics. I assume you are gonna use spray cans or you usin a spray gun?
Old Oct 31, 2012 | 07:43 AM
Bradle's Avatar
If you mixed yellow & light brown colour then paint your bike with that colour with adding some shiner such a great result appear after do it some artificial stickers & pasting chips past on it..... it will be amazing i think
Southpaw
Feb 19, 2012 03:03 PM
minime0616
Ninja 500R
Feb 20, 2008 03:42 PM
dm2GunzUp
Jul 11, 2007 09:27 PM
lefecious
Apr 15, 2007 05:21 AM
Bluebeast
Nov 10, 2005 03:44 PM
