Taking The KZ750 Carbs Apart... Again.
Old Oct 8, 2006 | 04:16 AM
markmeinteil's Avatar
Default Taking The KZ750 Carbs Apart... Again.
I haven't dug into the KZ yet, but I will need to mess with the carbs again. I was never able to remove the main jet on the #4 carb barrel the last time I had the carbs out. It was really seized up in there since the idiot before me didn't have a gasket on the #4 bowl letting the internals air out, and causing the gas to varnish. All I could do at the time was spray a crap-load of carb cleaner into the jet passage hoping it would take care of everything... It didn't.
Anyone have any good ideas on getting out a stuck jet without F*cking up anything? The bottom of the jet is already somewhat damaged from trying to remove it last time. I think I may have to use a dremel to cut a straight grove into it.
If that doesn't work, I guess it's on to ebay for some new carbs.[:'(]
Old Oct 8, 2006 | 10:03 PM
BigRig18Wheeler's Avatar
Default RE: Taking The KZ750 Carbs Apart... Again.
If possible man, let it sit and soak in a b12 solution overnight. If that doesn ot free it up, I don't know what will...
Old Oct 9, 2006 | 11:20 AM
Good news! I got the jet out.
I made a mistake in the prior post. It was the pilot jet that was seized, not the main. (although the #4 main jet was a bit dirty too when I checked it.) I ended up using the good ol' dremel tool to cut a groove into the top of the retainer screw, and out it came!
Here is a pic showing how messed up that head was:
Old Oct 17, 2006 | 08:08 AM
dam!!! That thing was dirty! Glad you got her out. Did you rebuild all the carbs? Where di you get the rebuild kits at? www.oldbikebarn.com ?
Old Oct 17, 2006 | 08:48 AM
Yeah, I went through all the carbs again when I took the carbs off for a second time. I did get the rebuild kits, but it was through a private seller on ebay.
Oldbikebarn's prices were at almost the same, but I had money in my paypal account waiting to be spent.
Old Oct 17, 2006 | 05:59 PM
Notstock's Avatar
Tea I bet those puppies are clogged. Glad you were able to get the pilot out. Even has brass floats, nice.
Metalcore
Mar 14, 2009 01:35 AM
ryanlong1
Jul 14, 2008 07:30 AM
Mr. Toad
Feb 2, 2006 06:50 PM
cartandretti
Jan 7, 2006 07:37 AM
