I need help gas leak
Old Jul 4, 2014 | 07:32 PM
pettyman1972's Avatar
Unhappy I need help gas leak
Just bought kz700 yesterday drove it home ran fine. this morning i noticed gas pouring from the plastic spacer in the the petcock. What do I do??
Old Jul 4, 2014 | 07:52 PM
Does the lever move to the OFF mode?
Could be that the hose worked loose on the petcock, or it is time for a petcock rebuild.
Old Jul 4, 2014 | 07:54 PM
yes it stops leaking when i do that, there is a little grove in that block spacer that the gas comes out of.
Old Jul 4, 2014 | 08:00 PM
the rebuild kit is fairly inexpensive.
Old Jul 4, 2014 | 08:08 PM
all the hoses are attached. its coming from between the plastic block and gaskets. there is this little groove in it, does the gasket go in there? why would it have an air intake there? I just wanted to ride today.
Old Nov 8, 2014 | 08:19 PM
Copbike's Avatar
Thumbs up leaking petcock
Well, I was faced with the same issue with the petcock on my KZ1000p. I had gotten this bike from an owner who stored the bike for 4 years with a full tank of gas. The gaskets, vacuum diaphragm and seals were shot, which caused the fuel leak.
I took the petcock apart a few times, thinking that I would be able to correct the leak condition. I quickly realized that the only way I could fix the leak would be to purchase a petcock rebuild kit. I got mine on Ebay. Once installed, NO MORE LEAKS! Make sure you know what you need when purchasing the rebuild kit or, you will end up with the wrong kit, like I did. Good luck!
dmojave250
Jan 29, 2009 02:18 PM
importmonkey
Jan 3, 2008 01:38 AM
BlueDevil636
Jan 2, 2008 03:16 AM
cassa63
500 LTD
Aug 29, 2006 06:56 AM
cassa63
Aug 17, 2006 09:37 AM
