GPZ750 Unitrak Rear axle
Dumb question time! Doing an '83 750 Unitrak build and looking for the correct sequence when installing the rear wheel. I put the axle through the adjuster, collar, wheel but what is next to go on the axle as it looks like the rear brake calliper bracket then the spacer before going through the other adjuster. If this is the case it is catching on the disk! If the brake brakes and spacer are reversed it exposes the bearing!! Have I missed/lost something?
