1986 ninja 600
Old May 4, 2010 | 08:47 PM
mn nice's Avatar
Default 1986 ninja 600
Anybody have info on igniter inputs. I am not getting output to 1&4 OR 2&3 coils. Pickup coils appear to be working. I have the factory manual, it says to swap out igniter (Ibought one on ebay and it doesn't work either). Coils ohm out. I would appreciate any help.
Old May 5, 2010 | 03:01 AM
so the pu coil resistance is 360-440 ohms? The manual does say to do the arcing test as well if you have the tool. 7mm or more distance. pg 15-21 in my manual. Welcome to KF and good luck with the progress.
Old May 5, 2010 | 03:30 AM
Prom's Avatar
No clue on what the input should be but as long as your getting anything from the pickups the coils should be firing. Is everything hooked up when you test it? If the output is not properly grounded who knows what the signal will look like.
marioc89
Nov 30, 2011 08:44 PM
midnight_shot
Aug 4, 2010 06:17 PM
jsnider1970
Apr 11, 2008 10:52 PM
famfedyk
Oct 31, 2007 02:50 AM
famfedyk
Oct 31, 2007 12:20 AM
