New bike running rough at very slow speeds.
My bike is only a week old with only 50 miles on it. It is jerky and rough at low speeds,
in first gear, it also makes what is almost a back-firing sound on deceleration. I took
out the gas the dealer put in and filled the tank with Premium (as it says on the bike) and
that did definetly help some, but the bike is not running as smooth as it should which
I need for my skill's test, going around the cones, etc.
Also I didn't get an Owner's Manual with the bike.. What is the black dial on the
right hand side of the bike, looks like a carb adjustment for gas or air? Is there
a diptick? How do I check the oil level?
Dealer says to wait until I have 500 miles on the bike.. Think he's being lazy about
warranty work.
Another dealer close by won't do the Warranty work for a bike that was bought at
another dealership ! I'm writing my Attorney General and the BBB about them.
Thanks
warranty work.
Thanks
Is this your first bike? If so, I'd guess that it's not the bike. When I first started riding it was jerky-city at low speeds until I learned proper throttle and clutch control. Often I'll have to use a little clutch to smooth out any changes at low speeds in speed or for really slow riding... Remember you have a wet clutch... they're made to be ridden a bit more as opposed to the clutch in your car. Did you take the MSF course? They do a great job of taking you through a lot of low-speed exercises.
You may have hit the nail on the head. I have ridden a Honda CX 500 before for a couple of
years but never had to take a skills test with the beast. Will try giving it a little clutch to see
if that helps the jerking.
Knew I should have bought that Honda Scooter 600cc with the Auto tranny..
norsseman in spokane
ORIGINAL: norsseman
Thanks for the directions on finding the engine oil level, it's filled half way. vn750 running good now
on Premium gas, but on long trips will probably use regular fuel. Only got about 25 miles per
gallon on my first tank, but I guess that is understandable during break-in.
Hard to keep it under 4000 rmp, it just wants to rev and take off. Definetly the best bike I've
ever had.
Dealer in Coeur d' Alene, Idaho has an Owner's Manual on order, but Kawasaki Motors, Inc didn't
believe that one wasn't with the bike..
Great forums at vn750.com, been using that sight for a lot of info.
ever had.
