Help
Old Nov 9, 2012 | 02:14 AM
Originally Posted by IDRIDR
Lisa,
You may have a stuck or poorly adjusted carb float that is allowing the fuel to pour through the carb, cylinder, and contaminate the oil, making it over-full and blowing out. Check your oil level before draining it and see if it is over-filled and if there is any hint of fuel there (smell it). I can see a grain of sugar or the sugar-slime-gunk sticking a float needle. Do you know how to check float level?
Change the fuel lines, filter, etc.
Good luck.
Do this as mentioned by IDRIDR
82ltd
Aug 26, 2006 06:02 PM
