Vulcan Vaquero starting problems
Old Mar 30, 2018 | 07:45 PM
melmo53's Avatar
Default Vulcan Vaquero starting problems
Having problems starting my 2013 Vulcan Vaquero. I turn the key, wait for it to cycle thru the startup process and then hit the start button. It seems to have plenty of juice in the battery because it turns over fast enough but it wont start. I have to do this process 3-4 times before it starts. I have tried to hold the throttle barely on, to see if it makes a difference. I have tried turning the key off again and back on and also have tried to just hit the start button, same results. Must mention that its in an unheated garage and temp is around zero. I previously had a 2005 Vulcan Nomad 1600, and did not have this problem, in cold weather. Any ideas?
Old Mar 31, 2018 | 05:26 PM
Rob9876's Avatar
Hello, almost all of the discussion here is around dirt bikes. You may get more responses in this forum: Kawasaki Vulcan Motorcycle Forums
melmo53
Mar 21, 2018 05:25 PM
rane1722
Sep 20, 2013 09:47 AM
rane1722
Aug 26, 2013 07:02 PM
SgtLawDawg
Dec 18, 2012 04:28 PM
Kingodawg
Apr 15, 2012 12:05 AM
