Side stand switch eliminator bypass
Old 11-27-2016, 08:25 AM
trf74's Avatar
Default Side stand switch eliminator bypass
Hi,
First post to this thread.
Bought an '09 KLX250s a few months ago, and last week
the side stand snapped off. Not particularly keen to muck around getting it welded back on, so disconnected the cut-off switch, but now need a switch eliminator bypass kit. Have found one on ebay, but it's in Greece. So a question for my fellow Australian members - does anyone know where I can get one in Australia? I think it'll arrive a heck of a lot quicker.
Cheers,
Tim.
Old 11-27-2016, 09:26 AM
zomby woof's Avatar
Cut the plug off and join the wires together
Old 11-27-2016, 12:18 PM
That or cut the wire from the side stand (leaving enough to reconnect if you ever get senile and want to put it back on) and solder the wires together. Then plug it back in.
With that kind of fix available I don't know why anyone would actually pay for a bypass.
Old 11-27-2016, 11:25 PM
zomby woof's Avatar
That's what I meant, and how I did mine
Old 11-28-2016, 03:21 AM
GBAUTO's Avatar
Butt connector splice has been working great on mine.
Old 12-02-2016, 01:41 AM
trf74's Avatar
Thanks for the suggestions guys. Decided to cut and join. Seems to be fine.
Old 12-02-2016, 06:48 PM
cmott426's Avatar
The wires from the switch run up the frame and underneath the seat and that is where it connects to the main harness. Simply unplug the switch and remove that section of wires and plug the male and female bullet connectors into each other in the main harnes. That will bypass the switch and it is free and nothing to cut or splice together.
Old 12-02-2016, 07:33 PM
Hoot's Avatar
How far back from the plug are those bullet connectors? I just took a short piece of wire and looped it into that connector then taped it up. Same thing i did for the clutch switch.
Old 12-03-2016, 03:10 PM
oldgypsy's Avatar
Pictures of the various alternatives would be nice.
With a new '94 KLR650, I didn't make 500 miles before the switch failed. So far the KLX250 has gone 3500 miles without a hiccup. Naturally, I've forgotten how I did the KLR.
Old 12-03-2016, 05:41 PM
Not bad to forget. It may not be the same. The KLX650 circuit is closed with the stand down, so it was simply unplugging the switch at the junction and tucking in the plug. The KLX250 is open circuit with the stand down, so it has to be closed when the stand is up or the switch removed.
I didn't take pictures because it was simply tracing up to the plug under the seat, cutting the wire on the switch side wiring a few inches from the end and, as I said, I think I soldered them together and done.
klx678
03-12-2014 10:38 PM
outerextreme
05-22-2008 03:22 PM
Davebert
04-04-2008 02:02 PM
WestOzKLX
03-25-2008 01:34 PM
bobm417
08-26-2007 04:44 AM
Quick Reply: Side stand switch eliminator bypass
