KLX 250S FI lamp idle 3k problem
Hi Forum,
My first post this forum , i have a problem my bike
2011 KLX 250S EFI , @11K
problem starting after month,
some time first start , some times after 2-3minutes
fi lamp on & idle speed fixing 3k rpm.
i did'nt find this issue many forum.
br
br
Welcome to the forum & just so you know 95% of the bikes on here are US carb model not FI.
Could be a pressure or vacuum lock in the fuel tank causing FI light.
Next time it doesn't start, open & close the fuel cap then try & start her again.
After 1 year solved solution,KLX ECU connector location 2 cables peeled sometimes short circuit chase
Before every sensor check long time searching!..
Services says tps,alternator,crankshaft sensor, Idle talks!..
gthomas17
09-30-2015 06:53 AM
