Bought a KLX300 cylinder. What gasket kit do I need?
Base gasket for both is the same. The 250 cylinder is thicker to the inside of the bore, so the gasket dimensions are the same. I see you mention a "kit". The only different gasket is the head gasket to fit the 300 cylinder. The heads are basically the same. Here's a good resource.
http://dpippin.com/klx/index_files/Page1666.htm
