Bought a KLX300 cylinder. What gasket kit do I need?
Old Aug 24, 2016 | 11:38 PM
queen of spades's Avatar
Default Bought a KLX300 cylinder. What gasket kit do I need?
Pulled the trigger on a KLX300R cylinder today. Should I order a top end gasket kit for the KLX300R or the KLX250S?
Old Aug 24, 2016 | 11:40 PM
Dash8's Avatar
No idea, as I have the 351, but congrats!
Old Aug 25, 2016 | 02:20 AM
Base gasket for both is the same. The 250 cylinder is thicker to the inside of the bore, so the gasket dimensions are the same. I see you mention a "kit". The only different gasket is the head gasket to fit the 300 cylinder. The heads are basically the same. Here's a good resource.
http://dpippin.com/klx/index_files/Page1666.htm
Old Aug 25, 2016 | 04:14 AM
Pika's Avatar
Get the 300 gaskets. The 250 head gasket will protrude into the 300 bore.
Old Aug 25, 2016 | 12:47 PM
Thank you.
Old Aug 25, 2016 | 05:00 PM
The plating looks a little bit worn at the top of the cylinder.
Who does quality plating for the best price? I used PowerSeal a couple years ago on a KX125, it was $184.
Old Aug 25, 2016 | 05:02 PM
Also the bike only has 4800 miles. Should I go ahead and have the valve seals replaced & maybe grind the valves too?
Old Aug 26, 2016 | 04:24 AM
GBAUTO's Avatar
Millennium Technologies in WI is another option. Millennium Technologies
Old Aug 26, 2016 | 12:06 PM
THey don't have prices listed and won't open for several hours. Anyone know what they charge for plating on a 300cc cylinder?
Old Aug 26, 2016 | 03:09 PM
snowdrifter's Avatar
Cylinder Plating | Millennium Technologies
