kfx450 fan issue
kfx450 fan issue
I have a 09 kfx450r and found that my fan is not working,checked a few simple things from the shop manual,however at no time/heat do I get power to the fan circuit at all.Anyone run into this ? any help appreciated
I've checked the wires going to the fan motor,fan relay(removed frt plastics)and temp sensor(behind cyl),I've checked these when at ambient temp and at upto 230 degrees when the fan should be on(with the exception of the sensor due to location when hot,don't have long enough probes on meter)but nothing in the circuit is energizing.once again any help appreciated
