2011 Mule 4010 Trans4x4 issue
My mule has an issue. It seems like it almost tries to cut out or cut off at higher speeds/rpm's. It seems almost like a governed holding it back or something. Any help would be greatly appreciated
Sounds like the TPS needs to be adjusted. You will need a special tamper proof torx driver. If your on the passenger side of the machine it wil be the TPS further away from you. This will adjust the high side. Start the machine, loosen both screws and move the sensor ( twist toward you for more high end, away for less .
