brake ligth does not work
Old 10-09-2009, 07:48 PM
axioma's Avatar
Default brake ligth does not work
Hello
I own a ninja 250 2008… now the tail light does not work. Only turn on when I use the front brake, but otherwise it does not work (not when the bike in running nor when I use the rear brake).
I don’t know the correct approach and how to solve this issue.
Thanks for your help.
Old 10-09-2009, 11:33 PM
95451's Avatar
Welcome To Kawasaki Forums.
Turn On Some Tunes And Enjoy The Ride.
They're a lot of Good Members Here and they will do there Best to Help You out with Your Questions. Sometimes It Takes A Little Longer Then Others. So, hang-in there.
Old 10-10-2009, 12:08 AM
axioma's Avatar
thanks 95451 for your welcome message.
now I already change the bulb one filament was broken.
Now the front brake and the tail light are working.
Now the next step will be to check the foot pedal switch
before this i checked fuses and wires for bad conecction.
how can i check the foot pedal switch?
Old 10-10-2009, 12:16 AM
Welcome to KF axioma
I would check continuity at the molex/connector from the pedal switch to see if it makes or not.
CousinLarry
07-03-2012 02:30 AM
axioma
Ninja 250R
10-13-2009 03:12 PM
IBxAnders
08-08-2008 02:59 AM
funtoos
03-28-2006 09:04 PM
Quick Reply: brake ligth does not work
