DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your bike as told by your fellow members.
How to take off front wheel?
Old 08-23-2016, 08:44 PM
karlgreenblatt's Avatar
Default How to take off front wheel?
Need step by step for a 300klx
I still need step by step instructions on how to take the wheel off
I took out the screw but speedo cable would not twist or pull out?
Old 08-23-2016, 09:10 PM
You shouldn't need to remove the speedo cable to remove the wheel.
Leave the cable connected to the speedo gear.
Old 08-23-2016, 09:58 PM
Default still needing step by step
still needing step by step to remove wheel
Old 08-25-2016, 05:47 PM
Brieninsac's Avatar
It's in the user manual too. It's a pretty simple procedure. Simple enough to do it yourself on the side of the road with the supplied toolkit.
Old 08-25-2016, 09:07 PM
I have to say if it is that serious an issue to remove the front wheel you might have someone else do it.
Simple to do:
  • Loosen axle pinch clamp nuts
  • Loosen and remove axle
  • remove speedo drive and move it out of the way.
  • spacer will drop out on brake side
  • roll wheel out.
  • do whatever you need to do
  • wedge brake pads apart with a large screwdriver or other tool to get clearance for the rotor to fit back in easily.
  • roll wheel into position, put spacer in place maybe with some grease to kind of stick it in there
  • fit speedo drive
  • line everything up and slide axle in
  • torque axle
  • pump front brake up again
  • bounce the front end a few times to get everything settled in place
  • tighten the clamp cap nuts - I think the top ones are tightened fully clamping at the top, then the bottom are torqued.
I think I got everything there.
Licorne98
ZZR 600
02-14-2009 10:01 PM
Sid Post
01-27-2009 01:46 PM
Worlok14
05-02-2008 09:54 PM
bo142s
11-01-2007 02:26 PM
spooknick
02-12-2006 08:21 PM
Quick Reply: How to take off front wheel?
