How to take off front wheel?
Need step by step for a 300klx
I still need step by step instructions on how to take the wheel off I took out the screw but speedo cable would not twist or pull out? |
You shouldn't need to remove the speedo cable to remove the wheel.
Leave the cable connected to the speedo gear. |
still needing step by step
still needing step by step to remove wheel
It's in the user manual too. It's a pretty simple procedure. Simple enough to do it yourself on the side of the road with the supplied toolkit.
I have to say if it is that serious an issue to remove the front wheel you might have someone else do it.
Simple to do:
I think I got everything there. |
