Second gear dropout
Old Nov 5, 2012 | 11:02 AM
metallic92's Avatar
Default Second gear dropout
Hi all, i bought a 1992 zzr600 and keeps dropping out of second gear with just a little acceleration. i eventually got the motor out and found a shifting fork ground away on one side. Should just replacing the fork be a good enough solution or is the ground out fork just a symptom of the problem? Any help is appreciated.
Old Nov 6, 2012 | 12:57 AM
Do a visual check of the drum grooves, gear groove, gear positioning lever spring, the shift fork pin for any abnormal wear or slack. Replace the fork, install a dyno oil and a new oil filter for flushing the bike. Change both soon after running the bike throughout the gears a few times. You should be good to go after that.
california dreaming
Oct 1, 2013 05:13 AM
green636
Jan 7, 2007 05:50 AM
Chris90Ex5oo
Ninja 500R
Apr 10, 2006 08:10 PM
spooknick
Feb 12, 2006 08:21 PM
c10
Feb 6, 2005 06:21 PM
