05 636 second gear slip??
Old Jan 5, 2007 | 05:24 AM
green636's Avatar
Default 05 636 second gear slip??
when i riding normal or hard when i go to second gear it will stay till about 3500 rpms then kick in to nutral this is the only gear that it happens in anyone else have this problem? is it the out put shaft or would it be the gear? i know the clutch is fine so please help me
Old Jan 5, 2007 | 05:43 AM
mmi86's Avatar
Default RE: 05 636 second gear slip??
more than likely your slider gear on your main shaft is worn and letting it slip back down or its a worn drums, either way and no matter what ur splitting the cases good luck keep me posted, when i got to school tommrow ill ask a K-tech teacher just to make sure
Old Jan 5, 2007 | 05:46 AM
evil636's Avatar
Knee Dragging Pimp
that or your not getting it into gear all the way. had that happen a few times on my 9. turns out i needed to lower the shifter so i could engage it with less effort. all good. keep us posted on whats up.
Old Jan 5, 2007 | 07:30 AM
mmi86's Avatar
true very true, Maybe shift detent? but it would do it all gears right evil?
Old Jan 5, 2007 | 08:11 AM
steve214989's Avatar
Riding hard and shifting into second at 3,500 rpm? There's your problem. Try riding hard and shifting into second gear at 12,000 rpm. Sorry, just my 2c.
Old Jan 5, 2007 | 09:25 AM
evil636's Avatar
Knee Dragging Pimp
shift detent failure/seazure usually occurs when the shaft gets so hot that the bearing on the end of it welds itself to the shaft and causes the tranny to lock up and you wouldnt be able to move the lever at all. plus this is usually common on yamahas. looking at some microphish and going off of memory, id have to agree on shifting at a low rpm. could also be the chain is not adjusted right causing it and second gear is catching brunt of it. weird that its only 2nd everything else is fine so im sticking to your not getting it in gear/halfing it so its popping out. that there is a common problem.
Old Jan 6, 2007 | 01:09 AM
green636's Avatar
im pretty sure im in second all the way if i put in second gear and i can drive in second as long as the rpms are under 3000 or so but if i try to accelerate over 3000 to 3500 it will slip out i think i will just pull the case and check my shaft i realy just don't want to take it to kawasaki as they quoted me at least 1200 for labor and parts if it happens to be the shaft but said he would not know what it was untill he started working on it i will keep everyone posted on what i find.
Old Jan 6, 2007 | 02:25 AM
evil636's Avatar
Knee Dragging Pimp
have you tried shifting it around 10 thousand and going into 3rd around 8 to 10 ?
Old Jan 6, 2007 | 03:56 AM
green636's Avatar
once in second gear i can not go over 3500 max before slipping out i have to go straight to third when i shift from first to second at 10000 when i let off the clutch it goes untill i try to accelerate i can decelerate second gear tho just fine only on acceleration does it slip
Old Jan 6, 2007 | 06:23 AM
evil636's Avatar
Knee Dragging Pimp
so if you drop a gear into second, its fine ? then if you try to accelerate it pops out ?? did i read that right ?
