Off Road Taken your quad or bike off roading lately? Talk about it here.
01 Prairie 360 starter problem
Old 01-03-2012, 11:34 PM
TrailBlazer's Avatar
Default 01 Prairie 360 starter problem
So brand new to this forum but on one for my car so I know the routine and couldn't find anything about this issue. When I go to start my quad, I get a very very rapid clicking before I notice the pump kicks on to get the quad fired up. I dunno if the clicking has anything to do with a bad wiring set up. Let me know and I can give more details.
Old 01-04-2012, 02:27 AM
BleednGreen68's Avatar
Sounds like bad connection, low or bad battery, bad starter or solenoid. How old is the battery?
Old 01-04-2012, 02:48 AM
wow, BnG68 covered all of the possible issues in a sentence. Nice job.
Check the connections first, but there generally is a need to replace the battery with your symptoms.
Old 01-05-2012, 02:17 AM
Thanks Dragone! Thats one of the main things that happens to atvs that come in our shop. Most of the time they sit so either battery is bad and connections are corroded or the carb is plugged. Also the 360's had a valve problem. In the kawasaki repair manual they give the correct specs. Usually you go inbetween what kawi says in the book. Well there is actually a bulletin or supplement that says set the valve lash bigger side of the valve lash settings. The compression release on those machines are a bit finicky. Also drill out the idle mixture plug and richen it up a bit if it hasnt been already done. Both those will cause a hard to start prob.
Old 01-05-2012, 03:23 PM
Awesome. Thanks for the help guys. To be honest I don't know how old the battery is and my neighbor who I bought it off of might not know either. I'm def going to try the battery first and get a new one. I went threw all the connections and fuses and they seem fine. Nothing corroded. If the battery doesn't do it I'll know it's on to the next part. Will let you know if problem gets fixed. Thanks again.
FLYINPALMYRAN
11-27-2007 04:01 PM
Ty
10-01-2007 11:45 PM
armadilla
11-02-2006 09:14 PM
abrooks19
12-09-2005 03:06 AM
artieboy05
08-09-2005 02:07 AM
Quick Reply: 01 Prairie 360 starter problem
