I have a problem
Old Aug 14, 2007 | 11:38 PM
Treyzx9's Avatar
Default I have a problem
I have a 2000 ZX9, i'm having problems with it cuting out in 3rd gear, and up. It was running fine then it rained and was left out. Is it possible that any sencers are bad any other help would is most welcome.
Old Aug 15, 2007 | 02:48 AM
Default RE: I have a problem
Did you read the forum rules???? hmm, pwi can request your ride..... hahah, ok, messin'
Have you checked out your molex connectors, cleaned and reattached?
Welcome to the forums.
Old Aug 15, 2007 | 01:03 PM
jeffzx9's Avatar
Sounds like a moisture problem. +1 on Dragone; check your connectors. You may also want (need) to take tank off to view airbox and top of motor to see if you have water accumulated in any vital spots. Leave the bike out in the sun to see if it helps dry out. (Temps in southern Ohio have been in the mid 90's; shouldn't take too long to evaporate.) Rule out moisture, then let us know.
floor
Sep 1, 2008 12:18 PM
iORi
Ninja 250R
Nov 21, 2007 10:53 PM
Notstock
Aug 30, 2006 09:08 AM
stuntzx6r
Jul 21, 2006 05:14 AM
shawn_460
Jul 15, 2005 07:24 PM
