another question for my 2000 zx9
Old May 11, 2009 | 09:33 PM
ruff9012's Avatar
Default another question for my 2000 zx9
i have a 2000 zx9..my brake lights for my hand brake work.but the lights for my foot brake DONT work..anybody know what it could possibly by??
Old May 12, 2009 | 11:16 AM
jeffzx9's Avatar
Sounds like it might be the switch or the wiring. Look at the contact switch coming off the brake pedal. Sometimes, the little metal slider (where the small spring connects the pedal to the switch) will get hung up and not want to slide in the housing. Use just a dab of dielectric grease to lube the slider. I'm not a big fan of this setup.
If it's not that, make sure your wiring is good coming from the switch, and also where it connects to the lights. Can also be a bit of corrosion in the light sockets.
If that still doesn't fix it, post again; we'll find it.
Old May 15, 2009 | 01:03 AM
jeffzx9's Avatar
Hey ruff! Did you get your problem solved?
ruff9012
Ninja ZX-9R
May 28, 2009 04:20 PM
ponezxr
Jun 8, 2007 05:50 PM
green latern
May 3, 2007 03:27 AM
ponezxr
Oct 17, 2006 04:04 PM
lucas8888
Apr 9, 2006 02:37 AM
