oil Filter?
Old Jan 29, 2008 | 02:39 AM
ezrollin's Avatar
Default oil Filter?
What oil filter do you all use?
I know Purolator "Pure One" filters are the best.
I'm just trying to figure out which one I should get.
I got the PL14160 (the longer one) I hope it fits and is the correct one!
The shorter one is PL14162 I believe
These are the correct model numbers for my friends R1
thanks alot
Old Jan 29, 2008 | 02:59 AM
bigbrew's Avatar
Default RE: oil Filter?
i used a fram, i try to change the oil every 3k, i think there all about the same nowadays, as long as you change them when you do oil you should be good
Old Jan 29, 2008 | 08:24 PM
ezrollin's Avatar
Update.
I installed the P14160 Purolator "Pure One", which "Pure One" is the best filter and used Shell Rotella full synthetic 5w-40.
I've driven for at least 40 miles now and no problems.
But I was worried because on the right side of the bike theclear screen where you SHOULD be Able to see oil flowing in the engine.... I see no oil in it.
My friend has an R1 and when he starts his bike up you can see oil flowing.
WTF?
thanks
Old Jan 29, 2008 | 09:05 PM
1 bike off
2 bike level
3 oilshould cover 3/4 of the window
Old Jan 29, 2008 | 09:16 PM
ezrollin's Avatar
well it doesnt have ANY oil in the transparent clear window (on or off).
On my friend's R1 you cant see oil until you turn it on.
I KNOW I put in enough. It calls for 3.6L when installing a new filter.
I probably even put in too much.
Man, I would love to rebuild this engine and start fresh as well as diagnose any problems that arises.
I LOVE chokes now. Its like a decent option which will let you get the engine moving without having to disconnect fuel (and/or) spark, so that you can get oil flowing through the engine Prior to starting it on a fresh oil change or after a rebuild.
^sorry for the run-on sentance
Old Jan 29, 2008 | 10:36 PM
then tell ur freind he's low on oil, it's a sight glass to see the oil. litersand qaurts are different
Old Jan 30, 2008 | 12:35 AM
ORIGINAL: hoedogg
1 bike off
2 bike level
^+1 1/2-3/4 sight glass level. With new oil, a flashlight is nice to have to view the window level.
Highbeam
Sep 9, 2022 11:26 AM
MJohnson
Ninja ZX-9R
Mar 20, 2011 03:17 AM
yjsjin
Jul 12, 2009 12:28 AM
bryantjt
Sep 22, 2006 12:10 PM
Steve Ninja Strombol
Ninja 500R
May 13, 2006 05:52 PM
