NEED HELP --- L.E.D. signals
Old Apr 6, 2007 | 02:12 AM
brnr17's Avatar
Default NEED HELP --- L.E.D. signals
i put an undertail on with integrated LED stop/turn signals and i put front flush mounts with 18 bulbs in each front signal. i hooked everything up correctly. now when i hit my turn signal not only do they flash fast but all 4 signals flash at the same time. what should i do?!
Old Apr 6, 2007 | 02:17 AM
suprakawigrl's Avatar
Default RE: NEED HELP --- L.E.D. signals
you may need to hook up a little relay for the LED's some call them load equalizers. check out Targa or if you cannot find one I will see if I have some in my catalogs. What brand of undertail did you use? Usually most models have to the option to buy the relay.
Old Apr 6, 2007 | 02:32 AM
brnr17's Avatar
it had the option ... but will that fix my front signals too?
joelcool64
Sep 28, 2011 02:09 PM
Ninja_Huah
Oct 23, 2009 10:21 PM
mikess06
ZZR 600
May 14, 2008 03:16 PM
brnr17
Apr 6, 2007 08:01 PM
Cold Iron
Aug 12, 2006 09:18 AM
